Replacement for dyndns
Other related stuff
skopo
Has thanked: 8 times
Been thanked: 16 times
Unread post by skopo »
Just got email this morning that dyndns free will be canceled for 30 days now.
What do you use for dns forwarding?
I've been using dyndns 4-years now (because its free)
I'm using subsonic.org forwarder for madsonic but other services will be problem.
What would be replacement?
What are you using?
Has thanked: 11 times
Been thanked: 105 times
Re: Replacement for dyndns
Unread post by gurutech »
x2 on the no-ip.com - that's what I'm using. I do pay like $12.95 for 2 years of extra domain names, as I use more than just the 3 they let you use for free, and I use some of the "non-free" domain names they have available.
skopo
Thanks now my router is paired to no-ip without any problems.
I'm running tomato so I had quite list what to use.
justin
Unread post by justin »
skopo wrote:Thanks now my router is paired to no-ip without any problems.
I use freedns.afraid.org with tomato. Have never had any probs
kornkid5622
Has thanked: 4 times
Unread post by kornkid5622 »
i was just going to post freedns.afraid.org i started using them when Dyn started doing the "you have to login every 30 days to keep your domain" thing and it works just fine, i'm using it with DD-WRT, so it's compatible with most custom router firmware it seems :)
DoCC
Has thanked: 40 times
Been thanked: 65 times
Unread post by DoCC »
mh i have enabled the ddns option at my regular domain provider.
i have several domains registred via regfish.com ...
so i have , ok not free, but included : ) limitless ddns entries avail.
ip4 ip6
cname alias mx ptr
everything one can use building his own network ; P
utopian
Unread post by utopian »
duckdns
These users thanked the author utopian for the post:
don
