Replacement for dyndns
Posted: 09 Apr 2014, 05:49
by skopo
Just got email this morning that dyndns free will be canceled for 30 days now.
What do you use for dns forwarding?
I've been using dyndns 4-years now (because its free)
I'm using subsonic.org forwarder for madsonic but other services will be problem.
What would be replacement?
What are you using?
Re: Replacement for dyndns
Posted: 09 Apr 2014, 10:45
by madsub
Posted: 09 Apr 2014, 21:38
by gurutech
x2 on the no-ip.com - that's what I'm using. I do pay like $12.95 for 2 years of extra domain names, as I use more than just the 3 they let you use for free, and I use some of the "non-free" domain names they have available.
Posted: 10 Apr 2014, 06:18
by skopo
Thanks now my router is paired to no-ip without any problems.
I'm running tomato so I had quite list what to use.
Posted: 19 Jun 2014, 02:11
by justin
skopo wrote:Thanks now my router is paired to no-ip without any problems.
I use freedns.afraid.org with tomato. Have never had any probs
Posted: 05 Jul 2014, 21:53
by kornkid5622
justin wrote:skopo wrote:Thanks now my router is paired to no-ip without any problems.
i was just going to post freedns.afraid.org i started using them when Dyn started doing the "you have to login every 30 days to keep your domain" thing and it works just fine, i'm using it with DD-WRT, so it's compatible with most custom router firmware it seems
Posted: 18 Dec 2014, 08:49
by DoCC
mh i have enabled the ddns option at my regular domain provider.
i have several domains registred via regfish.com ...
so i have , ok not free, but included : ) limitless ddns entries avail.
ip4 ip6
cname alias mx ptr
everything one can use building his own network ; P
Posted: 23 Dec 2014, 16:31
by utopian
duckdns
