New Install
Unread postPosted: 08 Aug 2015, 04:50
by don
Hi all - hope this is the best place to post this.
I had Ampache installed, and basically been pissed off with it for a while. The android clients are not that good, problems all the time. I had not installed Madsonic as I was a bit concerned about overloading my server even more with Java.
But it is running quite well - or as you young things would say - like totally like awesome. Android client is great. Only problem is the organisation of my music library ... that *may* be my fault.
Anyway - great job. Glad I got round to giving it a go.
Don
