Android clients not working after 5.1 upgrade
gerbilfur
Unread post by gerbilfur »
I was running 5.0 Standalone on OS X 10.9.5 and everything was working great. I just did a fresh install of 5.1 Final running on Jetty (on default jetty port 8080). It's working really well, performing very smoothly and quickly. However, when I try to connect from either the Madsonic or Ultrasonic apps on Android, I get the following error when testing the connection:
Connection failure. length=38; regionStart=0; regionLength=-1
Trying to use the app gives me this error:
java.lang.StringIndexOutOfBounds Exception: length=38; regionStart=0; regionLength=-1
Everything from a computer browser works perfectly. What did I do wrong? Thank you! Great job on this update, can't wait to use Pandora from my phone.
cheers
gerbilfur
Re: Android clients not working after 5.1 upgrade
Nope nope, I'm an idiot. I left out the /madsonic on my connection URL, which was necessary after switching to Jetty. I was running at the root before. durrrrrrr
Magica
Unread post by Magica »
I noticed same thing after clean 5.1 windows 64bit install.
Had to downgrade back to 5.0.3880
Br
-m-
