madsonic on bananian (debian wheezy)
mad1993max
Unread post by mad1993max »
Hi i have troble installing the new madsonic 5.1 server on my arm pc
i tried to install the dependencies first: i installed openjdk-7-jre-headless and then i installed the madsonic .dep via dpkg -i, but i got dependencie errors
so i tried using apt-get -f install which downloaded openjdk-6-jre and java-defaults and some java libs, and then it installed madsonic
but i wasnt able to navigate to the login page and i ckeckt the daemon wasnt running althou it displayed is.
my question is now: what are the exact dependencie packages of madsonic on debian? and schould i use oracle instead of openjdk and which version?
DoCC
Has thanked: 40 times
Been thanked: 65 times
Re: madsonic on bananian (debian wheezy)
Unread post by DoCC »
if installed , and you are able to start stop via /etc/init.d/madsonic start or stop but the deamon just won't fire up
check /var/madsonic/madsonic_sh.log
if you are not able to install til the end, do some research in the system logs of /var/log/system or apt (if apt is configured to log issues )
any debian based system basicly just needs openjdk-6/7-jre and the madsonic installer . if errors occur you might search deeper in your logs
i used to run subsonic an madsonic under debian 5.0 and ubuntu 10 / 12 no issues known
mad1993max
OK the problem was that something dindt went right with the change of the deault Java environment and so devaul-jre pointed to a version which wasnt installed
After purgig all java related pakages and reinstalling
Changing the devault java version from 6 to 7
installing devault-jdk
Everything went right
These users thanked the author mad1993max for the post (total 2):
MadsonicDoCC
Rating: 15.38%
