Hi all,
I just switched from Subsonic to Madsonic thanks to all the great features. Great job lads. I ran into snag though. After clean install I recreated users (using the same credentials), injected my subsonic licence tested users logins locally and from mobile (using data no wifi) and all seemed to be ok until users tried to login. Logins are being rejected when accessing via web (though their mobile apps work fine after the switch). Is it a glitch and is there fix for it? In one case I even created a new user and he still could not connect with credentials provided. It is not the access problem as ports are properly forwarded and exception is created in the firewall. They are able to get to login screen but no further. Any help would be appreciated.
Thank You.
LB66
Madsonic 5.1
Jump to
- ↳ Info / Announcements
- ↳ Voting Polls
- ↳ Madsonic Client
- ↳ Support
- ↳ Feature Requests
- ↳ Madsonic Node
- ↳ Support
- ↳ Madsonic Server
- ↳ Info
- ↳ Support
- ↳ Plugins & Addons
- ↳ Docker
- ↳ UnRAID
- ↳ FreeBSD
- ↳ FreeNAS
- ↳ Synology
- ↳ QNAP
- ↳ OpenMediaVault
- ↳ Netgear
- ↳ Asustor
- ↳ MusicBee
- ↳ Tomahawk
- ↳ XBMC
- ↳ Clementine
- ↳ KODI
- General
- ↳ Info
- ↳ Announcements
- ↳ Voting Polls
- ↳ General
- ↳ Development
- ↳ Development Voting Polls
- ↳ Client 6.x
- ↳ Info
- ↳ Support
- ↳ Bug Reports
- ↳ Solved Requests
- ↳ Server 5.x
- ↳ Support 5.x
- ↳ Bug Reports 5.x
- ↳ Feature Requests 5.x
- ↳ Server 6.x
- ↳ Info
- ↳ Support 6.x
- ↳ Bug Reports 6.x
- ↳ Feature Requests 6.x
- ↳ Solved Requests
- ↳ Node 6.x
- ↳ Info
- ↳ Support
- ↳ Download
- ↳ Madsonic 6.x
- ↳ Madsonic Transcoding
- ↳ Player / Tools / Themes
- ↳ Scripts
- ↳ Off Topic
