java install ok but dosnt start
kento
Unread post by kento »
hi all
installed the v8 version and looks alright on my synology ds413
BUT dosn't start.
should it not start by it self???
how do i fix this witout installing other stuf and messing arround with telnet and other shi**
greetings from denmark
kento
Re: java install ok but dosnt start
ok got java se embedded 1.8.0-1 installed and it runs, and perl runs to.
but when trying to install madsonic it says that java_home is not defined?? what is all that all about? someone that can help?
it should be running on my synology DS-413 with DSM 5.1
but as said no luck yet.
hope someone can helt me on this.
