How to upgrade to 5.1 on a QNAP NAS?
Unread postby VikingOy » 04 May 2015, 18:39
Hi All,
Does anyone know how to upgrade Mediasonic on a QNAP TS-119 NAS (ARM) from a tar ball or a zip?
The QPKG installation package offered by QNAP is version 5.0.3630.beta5 while Madsonic has 5.1 out, but this is not yet available as a QPKG.
Any help is appreciated.
Rgds
VikingOy
Has thanked: 3 times
Re: How to upgrade to 5.1 on a QNAP NAS?
Unread postby mrwebguy » 22 Jun 2015, 04:20
I'm also looking for the upgrade path on the QNAP qpkgs.
mrwebguy
Unread postby tjay78 » 30 Jul 2015, 08:16
Install Tomcat on your Qnap
And then install Madsonic tomcat version ...
It works fine.
T-J@Y
tjay78
Unread postby VikingOy » 15 Aug 2015, 17:20
Do you have a step-by-step guide, including links to all that's needed?
Sent from my SM-G900F using Tapatalk
VikingOy
[SOLVED]: How to upgrade to 5.1 on a QNAP NAS?
Unread postby VikingOy » 23 Apr 2016, 13:11
The solution is here: viewtopic.php?f=14&t=1770
VikingOy
Return to Support 5.x
