ned to get pointed to the file location of kbps
chali
Has thanked: 18 times
Been thanked: 35 times
Unread post by chali »
hi
where can i change the bit rate so users only see 2000kbps and not more?
regards /chali
Skinjob
Been thanked: 10 times
Re: ned to get pointed to the file location of kbps
Unread post by Skinjob »
I thought you could do it with the new Groups feature, but it looks like it just sets the default bitrate, not the max. I haven't tried it though, so I'm not 100% sure. Have you tried it?
It would be nice if you could set default and maximum bitrates at the player, user and group levels for both audio and video.
chali
hi
it seams to be just for default =(
would be nice if some one could point me to the fil
/Chali
Skinjob wrote:I thought you could do it with the new Groups feature, but it looks like it just sets the default bitrate, not the max. I haven't tried it though, so I'm not 100% sure. Have you tried it?
