I have albums that have "Part 1" or "Part 2" in the Album name, for example:
Harry Potter and the Deathly Hallows, Part 1
Harry Potter and the Deathly Hallows Part 2
But it's getting re-written into:
Movies - Disk 1
Movies - Disk 2
Which is odd considering they are Soundtracks and I can't find the word "Movies" anywhere in their tags.
Additionally I have classical CDs with Titles like:
Fidelio (Act 2) - W. Furtwagler
Rewritten into:
Ludwig van Beethoven - Disk2
I've tried to change the mediatype of the directory, but with little effect. Any suggestions?
Albums with "Part"/"Act" assumed to be multidisc [Solved]
- Been thanked: 5 times
Re: Albums with "Part"/"Act" in name assumed to be multidisc
There are new settings available since the 5.0.3630.beta5 build that fix this. The settings allow you to disable any special parsing of the album names and just use the tag/folder name as is:
http://forum.madsonic.org/viewtopic.php ... =716#p1728
Note that you have to do a full rescan after you change the settings.
FYI - I think the strange "album" names you are seeing either come from the album artist tag or the parent folder name of the album folder. In my case these are always the same so I'm not sure which one is being used. Prior to the new settings albums names like "album name (CD 1)" were getting changed to "artist name - Disk 1". Do your soundtracks by chance sit in a "Movies" folder? In any case, once you disable the folder and album set parsing and rescan, they should display as expected.
Re: Albums with "Part"/"Act" assumed to be multidisc [Solved
Hello folks,
My apologies for bumping old thread.
I've faced the same bug of parsing part of Madsonic (ok, i do believe this is a bug) about a week ago with some of my VA albums. Please see attached picture.
MADSONIC 5.2.5420.
As clearly seen from the screenshot above i intentionally use custom folder names for albums that differs from id3 tags, so i believe it's just incorrect to say that disabling this will "fix" something.
And i'm agree while some of the album tags in my case are far from perfect, others are absolutely valid - i.e. 'How To Destroy The Universe Part 5': http://www.discogs.com/Various-How-To-D ... ase/816449 I beleive we won't switch to 'discogs are lame' discussion...
So until Madsonic developer himself decides fix his parsing engine or not to use it anymore, we need to know that:
Enable AlbumSet/Folder Parsing + tags with "CD 1"/"Part 1"-like album names = Completely weird result
MADSONIC 5.2.5420.
Skinjob wrote:There are new settings available since the 5.0.3630.beta5 build that fix this. The settings allow you to disable any special parsing of the album names and just use the tag/folder name as is:
