Run Subsonic and Madsonic on the same PC/Server?
apastuszak
Unread post by apastuszak »
Is it possible to run Subsonic and Madsonic at the same time, but on different ports?
hanshans
Has thanked: 5 times
Re: Run Subsonic and Madsonic on the same PC/Server?
Unread post by hanshans »
yes, but why ? :-)
apastuszak
So, I can test my Subsonic clients and see if they work with the Madsonic back end.
skopo
Has thanked: 8 times
Been thanked: 16 times
Unread post by skopo »
I'm using Virtualbox and other lan-card for that.
These users thanked the author skopo for the post:
maxslug
Unread post by maxslug »
Yes.
I run both to try out new builds of each. on unix I install one in /var/madsonic and one in /var/subsonic
You just need two copies of the shell script, which you already have -- /usr/bin/subsonic and /usr/bin/madsonic
make sure that in there they point to the right directories, and assign them to different ports et voila.
-m
These users thanked the author maxslug for the post:
