Alnum-Folders instead of Tags
Unread postby madsub » 05 Jan 2014, 18:50
I have tagged all my MP3s.
Nevertheless I have build a folder-structure out of my tags that mainly has the structure
Albumartist\Album\Sometimes Volume
What I want is, that madsonic cares about my folders ALBUMARTIST and ALBUM and not their equivalent tags.
My album-foldername sometimes is slight different fom the album-tag on purpose.
I cannot find a way that madsonic takes the name of the album-folder and that breaks my whole structure inside madsonic.
How can it be done?
madsub
Has thanked: 2 times
Been thanked: 21 times
Re: Alnum-Folders instead of Tags
Unread postby Madevil » 05 Jan 2014, 21:04
this should really be the advantage of madsonic, maybe a parsing setting block this.
Can you give me a real example? Maybe a additional new setting can help in your case.
Has thanked: 1323 times
Been thanked: 962 times
Unread postby madsub » 06 Jan 2014, 18:55
Madevil wrote:Can you give me a real example? Maybe a additional new setting can help in your case.
Sorry but it started working again like before and I donÄ't realy know the reason.
I have 2 installations, one for testing, the other as a working server.
Both were Build 3830 but one showed the album-tags and the other showed the folder-names. In both cases "Sort albums by foldernames" was enabled.
I disabled foldernames, enabled it again, made a rescan and suddenly the foldernames worked again.
madsub
Return to Support 5.x
