Creating playlists
Creating playlists
Unread postby skopo » 07 Jan 2014, 11:14
I'm looking for method to make playlists with another software (for example winamp)
Because I like to create large playlists like one artist discography with 10 albums of music.
With webclien this is kinda hard and takes lot of time.
Server runs on ubuntu.
Anyone?
skopo
Has thanked: 11 times
Been thanked: 20 times
Re: Creating playlists
Unread postby gurutech » 07 Jan 2014, 20:36
I create playlists in iTunes, then export to *.m3u8 format, convert to supply the correct path as Madsonic would read it, then import them into Madsonic.
This is great for "genius" playlists, but would also work for full artist playlists.
Has thanked: 12 times
Been thanked: 131 times
Unread postby skopo » 07 Jan 2014, 21:21
gurutech wrote:I create playlists in iTunes, then export to *.m3u8 format, convert to supply the correct path as Madsonic would read it, then import them into Madsonic.
What are you using to correct paths because by hand in text file is no fun.. neither fast
skopo
Unread postby gurutech » 08 Jan 2014, 06:11
I created a script to do the conversion for me.... See: viewtopic.php?f=29&t=553
You'll just need to modify the paths. Create the VBS and CMD file in the same folder as your exported iTunes playlists.
You will need Windows to do this though. (I have a VM running Win8 that does this for me.)
Return to Support 5.x
Users browsing this forum: Google [Bot] and 3 guests
