[External player] Clementine player and subsonic
Tools & More for Madsonic
Unread postby jonnymnemo » 30 Jan 2013, 18:06
Some of you probably know Clementine Player.
They have added subsonic support in their latest beta !
Hope it will soon become a stable release !
http://code.google.com/p/clementine-player/issues/detail?id=1930
jonnymnemo
Has thanked: 5 times
Re: [External player] Clementine player and subsonic
Unread postby jonnymnemo » 31 Jan 2013, 15:42
If you want to try it, the dev version is here :
http://builds.clementine-player.org/win32/release/
It doesn't work for me, I suppose because of a ssl problem. :roll:
jonnymnemo
Unread postby Madevil » 01 Feb 2013, 10:28
wow, great player
8-)
SSL worked for me .. -> try https:// .... instead of http://... if you enabled SSL
Has thanked: 1338 times
Unread postby jonnymnemo » 01 Feb 2013, 14:49
I finally managed to make it work (using https:/xxx.xxx.xxx.xxx:port/), but the search engine for subsonic is not always accurate. But great player indeed ! ;)
jonnymnemo
Unread postby muiz » 28 May 2013, 22:29
Doesnt want to log in at my end.
edit: only if i use the ip number instead of the normal url
muiz
Has thanked: 4 times
Return to Player / Tools / Themes
