Android Client Early Adopter Program
Android Client for Madsonic
Unread postby Madevil » 04 Dec 2013, 21:41
You can join this program to access madsonic beta version for testing.
Join in https://groups.google.com/forum/?hl=en#!forum/madsonic
Login https://play.google.com/apps/testing/gi ... y.madsonic
Has thanked: 1339 times
Re: Android Client Early Adopter Program
Unread postby nh5 » 07 Dec 2013, 01:43
All is well so far no bugs to report however the same issue I've always had still occurs occasionally. If I'm downloading a big media file like a 120MB mp3. Sometimes it will continuously loop when downloading it. Normally playing it while downloading prevents it. But when pinning it to download it occurs pretty commonly. I've had this issue as far back as I can remember. Any idea?
nh5
Has thanked: 1 time
Been thanked: 8 times
Unread postby Madevil » 07 Dec 2013, 01:48
nh5 wrote:All is well so far no bugs to report however the same issue I've always had still occurs occasionally. If I'm downloading a big media file like a 120MB mp3. Sometimes it will continuously loop when downloading it. Normally playing it while downloading prevents it. But when pinning it to download it occurs pretty commonly. I've had this issue as far back as I can remember. Any idea?
hi there, i will recheck this.
Unread postby skopo » 07 Dec 2013, 10:01
Some times Artist-Title is not send over bluetooth.
Weirdly problem is fixed by listening one song in spotify. :D
skopo
Has thanked: 11 times
Been thanked: 20 times
Unread postby Clayboy » 07 Dec 2013, 10:11
login url seems like it's down getting an error... to get access to the beta channel
Clayboy
Has thanked: 7 times
Been thanked: 16 times
Unread postby Madevil » 07 Dec 2013, 10:33
Clayboy wrote:login url seems like it's down getting an error... to get access to the beta channel
to access the beta program
1. you must have bought the app through the google play store
2. join the Madsonic google group
3. join beta app page (2. link)
4. then i approve your request
5. google play store delivers beta apk
Unread postby drrighteous » 07 Dec 2013, 14:02
For what its worth, the issue nh5 is reporting sounds like the same one I reported in the Bugs forum. Where pinned files (often transcoded FLAC) repeat download, I have also noticed that these same files cut off the last second of audio when streaming live.. This does not however happen in the web based player. I do have a song or two that this behavior is repeatable on if you would like me to send a file to you on PM.
drrighteous
Has thanked: 1 time
Been thanked: 9 times
Unread postby boco » 07 Dec 2013, 15:55
Bug with Android 4.4 nexus 4 -
Clicking the Search icon on the bottom causes the app to crash. Bug report from app has been sent.
Also, where should we post bugs to? This Forum or the Google Groups list?
As always the new changes are looking really good.
Boco
boco
Has thanked: 69 times
Been thanked: 30 times
Unread postby Madevil » 07 Dec 2013, 16:40
boco wrote:Bug with Android 4.4 nexus 4 -
Boco
Hi there, i have tested with Android 4.4, but i will recheck your report.
it would be better post beta problems in the google group list,
and problems with released versions in the forum.
Unread postby rZn » 17 Dec 2013, 22:00
the login link does not work.. gives me an 404 at Google Play..
Regards.
Edit: Links works fine now (:
rZn
Has thanked: 15 times
Unread postby psychicsaint » 04 Jan 2014, 22:50
Google play reports item not found.. I've enrolled as tester.. please help
psychicsaint
Unread postby Madevil » 05 Jan 2014, 21:41
psychicsaint wrote:Google play reports item not found.. I've enrolled as tester.. please help
Please read this post: viewtopic.php?f=18&t=325&p=2518#p2498
Unread postby xicor » 23 Jan 2014, 03:35
it would be great if you could add the genre radio functionality that is on the full site.
xicor
Has thanked: 1 time
Unread postby kornkid5622 » 04 Jul 2014, 04:27
Bug with version 5.6 on Moto G Android 4.4.4
when turning on the Song Shuffle (now called pandora mode) it says "Pandora Mode On" but doesn't load any songs at all, when i press play nothing happens, worked fine in Madsonic 5.5, other then that it seems to work very nicely but i hope this can be fixed soon, as i love this feature of Madsonic!
edit: sometimes when i try to press play after enabling pandora mode it says "Pandora-Buffer 0"
kornkid5622
Has thanked: 4 times
Unread postby gurutech » 05 Jul 2014, 16:28
You may need to begin playing one song, then turn on Pandora mode.
Has thanked: 12 times
Been thanked: 131 times
Unread postby kornkid5622 » 05 Jul 2014, 20:53
gurutech wrote:You may need to begin playing one song, then turn on Pandora mode.
this workaround does get it working, thanks alot.
kornkid5622
Unread postby Madevil » 05 Jul 2014, 21:15
It's not a bug, it's a feature ;)
Pandora on the Client works a little bit different as on the Webpage.
First, play some Music of your choice.
In the background, the song data will be collected and a buffer is created on the base of these. If the last but one song is reached,
new songs are loaded from the buffer. By moving the song to the last entry, you can pass through songs from the buffer.
I hope I haven't confused you more as before. ;)
Unread postby kornkid5622 » 05 Jul 2014, 21:25
this makes perfect sense, i suppose the confusing part was just that in version 5.5 it was the same icon for the plain old shuffle feature, is there any way we will get the old shuffle option back? i want to shuffle my entire library not just similar artists/songs as it did in version 5.5. either way thanks alot for the reply and clarifying that feature :)
kornkid5622
Unread postby Madevil » 05 Jul 2014, 21:30
Yes it's there. Go to the welcome (first) page. In the Top bar the first icon is the old shuffle mode. :D
Unread postby kornkid5622 » 05 Jul 2014, 21:35
well, i suppose it was a bit of an oversight on my part then haha, thanks alot! the app is fantastic :)
kornkid5622
Next
Return to Client
