Madsonic Newsletter 07/2016
Unread postby Madevil » 27 Jul 2016, 10:14
Dear Madsonic Community & Early Adopters!
I'am proud to announce a couple of new Updates!
Searching people for troubleshooting new changes and features:
*) HLS transcoding tests
*) Dreambox integration
*) dynamical scanning
*) GUI workflow tests
*) Performance tests
*) Stability tests
*) Sonos tests
*) LDAP tests
Madsonic 6.1
new techtree build (for testing only, contains more debug log)
Madsonic 6.1 Node SDK
Madsonic Node:
Madsonic 6.x Synology-NAS PLugin
updated to the latest 6.1 build & full installer
DSM6 Installer: viewtopic.php?f=44&t=1777
DSM5 Installer: viewtopic.php?f=44&t=1575
Has thanked: 1326 times
Been thanked: 963 times
Re: Madsonic Newsletter 07/2016
Unread postby Nacrylyc » 04 Aug 2016, 20:15
Ok I just install 6.1 build 8550 with docker on QNAP NAS (with and without SSL activated) :
1) Don' t use a network bridge, use a "host" mode, the madsonic cannot find any sonos controller with bridge, normal the controller must be in the same subnet.
2) I test the connection with Sonos and doesn't work. I saw the service in the list and the log file is :
[04/08/16 19:00]    INFO    SonosServiceRegistration    Enabling Sonos music service, using Sonos controller IP, SID 244, and Madsonic URL
[04/08/16 19:00]    INFO    SonosServiceRegistration    Sonos controller returned: success!
But when I try to loggin on madsonic by Sonos, the information it's not reconized.
Finaly I didn't test other thing, I wait for Sonos cause it's the principal function I want.
Return to Announcements
