[Script] Script to rescan MediaFolders
Scripts for Madsonic
Unread postby Madevil » 10 Dec 2012, 04:41
some People want to trigger this more often as you can set in Madsonic.
i write a short windows script to trigger this action.
:: Rescan Madsonic ::
:: rescan Subsonic MediaFolders
set username=admin
set password=admin
set serverlink=http://127.0.0.1
wget %wgetsettings% --load-cookies=%temp%\cookie.txt --referer="%serverlink%" "%serverlink%/musicFolderSettings.view?scanNow"
rescan-script.zip
(1.71 MiB) Downloaded 504 times
Has thanked: 1339 times
Re: [Script] WGET Script to rescan MediaFolders
Unread postby boognish43 » 22 Jan 2013, 15:37
First post.. great job with madsonic!!
I went back to 4.6 after trying 4.7 since I wasnt able to see my media right when it was added.
I am playing around with Madsonic which looks incredible!!!! I see that when I add a new album i still need to refresh on the browser version before I can see it in the mobile app. I believe this script will solve this solution for me..is this correct?
boognish43
Unread postby Madevil » 14 Mar 2013, 02:55
boognish43 wrote:First post.. great job with madsonic!!
Since Build 3336 you can use instead the NEW REST APIs: startRescan, scanstatus
EXAMPLE:
http://localhost:4040/rest/startRescan.view?u=admin&p=admin&v=1.9.0&c=WebScript
http://localhost:4040/rest/scanstatus.view?u=admin&p=admin&v=1.9.0&c=WebScript
RESULT:
<subsonic-response xmlns="http://subsonic.org/restapi" status="ok" version="1.9.0">
<Scan>
<Status started="true" count="1052"></Status>
</Scan>
</subsonic-response>
<Scan>
<Status started="false"></Status>
</Scan>
Re: [Script] Script to rescan MediaFolders
Unread postby osef » 07 Jun 2014, 11:42
how to do this on linux please ?
Cordially.
osef
Unread postby rZn » 11 Jun 2014, 10:27
rZn
Has thanked: 15 times
Unread postby addseo1115 » 15 Aug 2015, 16:01
Just use these two in a browser.
addseo1115
Return to Scripts
