Simple start/stop for stand alone version
Scripts for Madsonic
Unread postby tokka » 22 Jun 2014, 11:00
I don't know if may be of some interest, but in case these are the scripts i use to start/stop MS from the desktop:
Assuming your ms standalone folder is in /var/madsonic
start:
right click on the desktop - create new empty document - open it with a text editor, than past
[Desktop Entry]
Encoding=UTF-8
Type=Application
Name=OFF
Name[C]=Madsonic
Icon=/path/to/preferred/icon (NOTE: in my case this don't works with ms, dunno why)
Exec=sudo /var/madsonic/madsonic.sh
Comment[C]=
save the file and rename it in "Madsonic start", or what you prefer;
stop:
right click on the desktop - new file - open with a txt editor, than past
#!/bin/sh
sudo killall java
save and close, rename it in Madsonic_stop (or what you prefer) than from terminal give:
cd Desktop
sudo chmod +x Madsonic_stop
In this way you can start/stop ms with a click from your Desk.
Hope this will be of some help
tokka
Has thanked: 5 times
Been thanked: 10 times
Re: Simple start/stop for stand alone version
Unread postby etyrnal » 24 Dec 2014, 10:03
sudo killall java
what if there are other java instances running that aren't related to madsonic??
etyrnal
Has thanked: 36 times
Been thanked: 11 times
Unread postby DoCC » 26 Dec 2014, 00:34
ps aux |grep java
ps aux |grep madsonic
root     14548  1.0 33.2 4589240 1346324 ?     Sl   Dec22  46:12 java -Xms512m -Xmx1800m -Dmadsonic.home=/var/madsonic -Dmadsonic.host=0.0.0.0 -Dmadsonic.port=4040 -Dmadsonic.httpsPort=0 -Dmadsonic.contextPath=/ -Dmadsonic.defaultMusicFolder=/var/media/artists -Dmadsonic.defaultUploadFolder=/var/media/incoming -Dmadsonic.defaultPodcastFolder=/var/media/podcast -Dmadsonic.defaultPlaylistImportFolder=/var/media/playlists/import -Dmadsonic.defaultPlaylistExportFolder=/var/media/playlists/export -Dmadsonic.defaultPlaylistBackupFolder=/var/media/playlists/backup -Duser.timezone= -Dmadsonic.gzip= -Djava.awt.headless=true -verbose:gc -jar madsonic-booter.jar
jan      29938  0.0  0.0  10464   936 pts/0    R+   00:30   0:00 grep --color=auto madsonic
top
htop
lets you get the PID of the java process responsible for madsonic ...
#kill pid ( i.e. kill 1234 )
or
kill -9 pid ( forced )
DoCC
Has thanked: 41 times
Been thanked: 71 times
Unread postby etyrnal » 22 Jan 2018, 18:38
For those trying to launch headless (macOS/OS X) at system boot, with no users logged in, this may help you figure things out:
Good INFO:
http://www.launchd.info/
and this amazing app:
http://www.soma-zone.com/LaunchControl/
etyrnal
Return to Scripts
