can't update my DB anymore
mea
Unread post by mea »
Hey everyone !
Since a few weeks My madsonic install is giving me a headache !
every night it scans the entire library but I get this error :
[4/3/14 3:03 AM] ERROR MediaScannerService ERROR PreparedStatementCallback; SQL [update media_file set present=?, last_scanned=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set present=?, last_scanned=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set present=?, last_scanned=? where path=?]
[4/3/14 3:03 AM] ERROR MediaScannerService Failed to scan media library.
- All my albums are present and listed in the left pane
- I can't find some of my albums when using the search textfield
- I tried to completely delete the db then make a new scan = Same issue
Wierdest thing, I see the SAME cover art that seems to illustrate some of the albums that are missing a cover in my collection (but not all...)!
have a look at this screenshot for your understanding :
http://prntscr.com/36kyi6
You can clearly see that "Quoth" album art by polygon window is shown multiple times...
I can't figure out how to fix this issue...any idea ???
FYI, the multiple cover art problem only appears in the WEB version of madsonic and does not appear when using Isub.
please, help ? ;)
triptol
Been thanked: 8 times
Re: can't update my DB anymore
Unread post by triptol »
Do a full rescan with cleanup. Normally does the trick for me when I have problems.
You can find it under: settings -> media tools.
