Artist page issue when selecting "All folders"
Posted: 13 Jan 2015, 02:59
by Larzon
I'm experiencing 2 issues with the artist functionnality. When I click on the "Artist" icon on the toolbar, I get a blank page and the search functionnality is not returning anything and I don't see the letters neither.
Also when I'm on an artist page (with the album listed). If I click on "Artist" I get only the "Artist TopTrack". The log doesn't show any error.
The behavior described above happens if I select the "All folders" from the dropdown (I have 2 media folders enabled).
If I select one (for example 'Dev'). The "Artist" tab will then display the letters above the search bar. In both case I get the following error in the log file:
[1/12/15 8:47 PM]	ERROR	ArtistController	## Failed to Fetch Data: ?
The other problem (Artist link under the artist image) is fixed when I select a specific Media folder (I see Artist Top Tags, Last.fm summary, Similar artists, etc).
Madsonic server information:
Version	MADSONIC 5.2.5420.20141214.0251
MADSONIC REST API v1.12.0
License	Madsonic Free Edition, for personal use only as described below.
Server	jetty/8.y.z-SNAPSHOT, java 1.8.0, Linux 3.12.28+ (arm) (79.9 MB / 193.6 MB)
Size: Database: 407MB, Thumbs-Cache: 62MB, LastFM-Cache: 9MB, Lucene-Cache: 1MB
Spring.Framework v3.2.12, Spring.Security v3.2.5
HyperSQL DataBase v2.3.2
WARNING no transcoder found!
Cheers
Re: Artist page issue when selecting "All folders"
Posted: 20 Jan 2015, 14:37
by Larzon
This problem happens only when I use the option "don't group" in the "Media folders" setting page
