Just a couple of things I've noticed so far.
Unread postby donpearson » 22 Apr 2013, 23:06
Hay, so far I'm liking madsonic.
I'm running the latest 4.8 build, it don't seem to run at all well in internet explorer (I just tested it to see what it looks like in ie).
I tried the 5.0 build but I found the scroll seemed to be running slow so I went back to 4.8 for now and I'm using chrome.
What's the Moods for? it always just says Please scan your library before.
That will do for now with my questions lol
But I do have a lot more as you seem to have a couple of the problems I had with subsonic since the changes in 4.7..
:D
donpearson
Re: Just a couple of things I've noticed so far.
Unread postby Madevil » 23 Apr 2013, 00:28
donpearson wrote:Hay, so far I'm liking madsonic.
:D
good to hear that you have not completely broken with subsonic/madsonic. ;)
Well, its a long story with the problems with the custom Scrollbar, but finally i will fix all issues. (tuning scroll speed)
you have several options to get around that.
1. check your mouse-wheel settings (scroll speed)
2. turn off custom Scrollbar in personal settings
You can use Moods only if your Mediafile-Tags support this.
INFO:
http://id3.org/id3v2.4.0-changes
http://www.jthink.net/jaudiotagger/tagmapping.html
Moods are only supported if you use ID3v2.4 Tags, if you have only ID3v2.3 it doesn't work! \c:=
To convert/fill & correct your Tags i used the following Tools
[*]MP3-Tag - http://www.mp3tag.de/en/index.html
[*]MusicBrainz Picard - http://musicbrainz.org/doc/MusicBrainz_Picard
[*]LastFMPlus - Extended Picard Tagging - http://wiki.musicbrainz.org/Picard_Docu ... Lastfmplus
Finally it looks like
Has thanked: 1339 times
Return to Bug Reports 5.x
