Version 5.0.3560.beta4 Dates
Unread postby BKKKPewsey » 18 Jul 2013, 23:52
Just downloaded the latest beta an noticed something odd.
I also added a couple of new albums at the same time and Madsonic is stripping the date info from the path from those NEW albums.
The Themata album I noticed had my old structure of <year> <album> (no hyphen) and did display correctly but when I changed it to add the hyphen ( hence MS thought it was new) the date then disappeared :roll:
The folder path contains the date in the format <year> - <album title>
Of course this is now messing up the sort as they are no longer in ascending date order
But the albums scanned in previous still display (and sort) ok
eg
:mrgreen:
BKKKPewsey
Has thanked: 4 times
Been thanked: 5 times
Re: Version 5.0.3560.beta4 Dates
Unread postby GJ51 » 18 Jul 2013, 23:58
So what's a Themata? :mrgreen:
GJ51
Has thanked: 68 times
Been thanked: 106 times
Unread postby Madevil » 19 Jul 2013, 00:19
there is a to enable/disable setting to hide/show the extracted year
Has thanked: 1338 times
Unread postby BKKKPewsey » 19 Jul 2013, 14:29
Madevil wrote:here is a to enable/disable setting to hide/show the extracted year
Yes I am aware - if I tick that option I get this :-
Note still sorting on alphabetical sort
The albums scanned in with the previous version still show correctly in date order
And to answer GJ - I have no idea :lol:
:mrgreen:
BKKKPewsey
Re: AW: Version 5.0.3560.beta4 Dates
Unread postby Madevil » 19 Jul 2013, 15:30
In the next build, a make a option to disable the year parsing.
Unread postby GJ51 » 19 Jul 2013, 16:08
I just hope that's not an imparsible thing to do ... :lol:
Still the best ... and only active version of Subsonic being worked on!!
Thanks Madevil - another support donation coming your way when 5.0 hits RTM.
GJ51
Unread postby BKKKPewsey » 20 Jul 2013, 02:31
GJ51 wrote:Still the best ... and only active version of Subsonic being worked on!!
Indeed!!!
:mrgreen:
BKKKPewsey
5.0.3560.beta4
Unread postby djiai » 21 Jul 2013, 21:09
hello,
I tested last night the new version. I think I found a bug.
1- Random way the lists of directories is accessed reactualize aléatoiremen every 10 seconds to 45 seconds.
Improper adjustment on my part or bug?
2- Is it normal to have 40 subsonic process during intensive use?
Sorry for my english! :?
djiai
Has thanked: 1 time
Return to Bug Reports 5.x
