Statistics in Artist pane is partially hidden
Unread postby jdubso » 05 Dec 2013, 16:26
On the left pane, just under the refresh button is the show statistics button. For the last several builds it is being cutoff by the divider.
jdubso
Has thanked: 8 times
Been thanked: 6 times
Re: Statistics in Artist pane is partially hidden
Unread postby gurutech » 05 Dec 2013, 16:47
I have the same problem. I can change themes to "fix" the problem, but for some reason it seems to revert back to the partially hidden line, even if it wasn't hidden before.
Has thanked: 12 times
Been thanked: 131 times
Return to Bug Reports 5.x
