[Solved] Editing JSP Files
Mission accomplished!
j3tblk
Been thanked: 5 times
Unread post by j3tblk »
I customize my installs. I installed 6 to check it out and again, it looks like you can't edit the jsp files.
Is there a trick to bypass the caching like there was in previous versions?
If so, could we get instructions?
lame-sauce = subscriptions. I would pay for timely tech support not features.
Re: Editing JSP Files
this comes from the precompiled JSP files of the default jetty version, you can simple use the madsonic tomcat version which don't use this. ;)
simple test of editing files from
\Madsonic\jetty\5260\webapp\WEB-INF\jsp
Hope this help you :D
j3tblk
There's no way to edit via the Jetty installs? Your link references Jetty and 5260. I'm trying to edit the jsp on 7200. Are you moving the Tomcat files over to a Jetty install?
yes of course, this works! :D
replace your jetty war with the tomcat war file! That's do the trick!
j3tblk
Awesome! I'm up and running.
These users thanked the author j3tblk for the post:
j3tblk
Re: [Solved] Editing JSP Files
Everything looks great. I noticed a few things that pushed me back to the old version: the "hot" feature on the Album covers isn't working. There's redundant data in the main window and the right panel.
The biggest deal breaker is the default "pop-up" action of the player and the queue. Even pinning it - it was annoying and too distracting. if you pin it down you lose your queue view.
In English 'Profile' is not 'Profil'
Just some contructive feedback to help with the final product.
I see where' you're going with the ads too - ughh. Terrible.
Make tech support and unique customization available for above and beyond payment and I'll gladly set up a re-occurring payment. My 2cents.
Thanks.
