[Solved] Install to Different Drive Besides ROOT - Win64
Mission accomplished!
boco
Been thanked: 13 times
Unread post by boco »
During the madsonic installation you can choose where to install, great. But it only places the madsonic .exe files and logs in this location. All other files including the DataBase, Jetty and Transcode files are placed on the ROOT drive. (ie: c:\madsonic)
Is it possible to place all madsonic folders into the same install location provided during setup? (ie: e:\madsonic)
To recap: If you select e:\madsonic as your install location during install it will create that location but also create a c:\madsonic location.
Ideally I want the DB off the ROOT drive spindle.
Thanks, boco
These users thanked the author boco for the post:
boco
Re: Install to Different Drive Besides ROOT - Win 64
Thank you for the new installer in version .7960
All files are now placed in the appropriate installation path! :)
