android client 5.5 crashes on podcast playback
Posted: 20 Feb 2014, 12:49
by binhex
hi madsonic, i am seeing a crash for madsonic 5.5 on android 4.4 (kitkat), if i attempt playback of a podcast by clicking on the bottom podcast icon and then select the podcast name and then the specific podcast session i want to listen to it crashes with "unfortunately madsonic has stopped", strangely enough the podcast actually starts streaming but the app is unusable, i have clicked on the report button, so hopefully you will see the crash report, i have put in a description of "crash on playback of podcast"
Re: android client 5.5 crashes on podcast playback
Posted: 21 Feb 2014, 16:24
Thx for report, i will investigate this issue.
Posted: 19 Aug 2014, 17:58
by eKeith
Similar problem:
I have been successfully using subsonic since the legacy "premium" days. I decided to install Madsonic and purchase the Android client specifically for the client podcast support, hoping that it would offer similar server-side sorting of podcasts (i.e. list by most recently downloaded). Unfortunately upon selection of the listed podcast, the client results in the following error "github.madmarty.madsonic.service.a.u: NullPointerException". Note that I am able to successfully browse and play the podcast by navigating to it using the "folder" tab. Unfortunately the sorting is by filename and my task at searching for the most recent podcast remains.
Madevil, can you please investigate this issue?
Thank you
