[solved] Cache Folder location selection
Unread postby troycarpenter » 04 Sep 2014, 17:12
Did the cache folder location selection get disabled in the latest client? I would still like to be able to change that from the default. My ROM disables the KitKat 4.4 security enhancement so I can use my SD card again. However, I would rather point the cache folder to a common music directory so all the differing music programs can use it.
troycarpenter
Has thanked: 19 times
Been thanked: 50 times
Re: Cache Folder location selection
Unread postby Madevil » 05 Sep 2014, 21:37
Yes, you are right, this is locked with Android Kitkat, but i will provide a fix for this issue.
Has thanked: 1338 times
Unread postby sanderd » 15 Oct 2014, 15:30
Thanks for the effort Madevil.
Is there a timeframe available for this fix?
(unrelated: is github MadMarty/madsonic-5.6 maintained, or do you push to github at release?)
sanderd
Unread postby norcalscott » 25 Jan 2015, 18:22
Bumping this - still unable to set the cache location on Lollipop. Any plans to take a look at this?
norcalscott
Has thanked: 6 times
Return to Support
