Movies Not Listed, but works in Web GUI
Unread postby jsgates » 21 Dec 2014, 02:29
In the Madsonic Android app I am not able to see any of the files in my "Movies" media folder. However, I can see them just fine via the Web Gui.
The folder structure for movies is like so:
\Movies\MovieTitle.mkv
Also, there is one folder in the root of the Movies folder titled "extrafanart" which is used by XBMC/KODI. Do I need to somehow exclude this folder in Madsonic so all of my movie files in the root of the Movies folder will show up in the Madsonic Android client? I also have the same issue in the Ultrasonic Android app.
Episodes from my "TV Shows" media folder display just fine, but they are in a folder stucture like so:
\TV Shows\TVShowTitle\SeasonX\S01E01-EpisodeTitle
jsgates
Been thanked: 16 times
Return to Support
