blocking caching on client
Unread postby loungecrasher » 27 Jan 2015, 03:55
Are there any madsonic or subsonic clients for IOS which block / stop caching if / or don't allow caching? I want to have a client that streams playlists but restricts copying of files for offline playback.
loungecrasher
Re: blocking caching on client
Unread postby skopo » 01 Feb 2015, 12:14
iSub can do that.
skopo
Has thanked: 11 times
Been thanked: 20 times
Unread postby loungecrasher » 03 Feb 2015, 18:14
My goal is to restrict Isub from being able to cache. I have isub running on an iPod at a restaurant. I don't want the staff there whom have access to the iPod, to be able to cache all the files played and potentially copy all the music.
loungecrasher
Unread postby skopo » 05 Feb 2015, 12:32
Enable song caching -> Off?
Maximum Cache Size -> 0?
skopo
Unread postby loungecrasher » 09 Feb 2015, 16:53
This feature I see in Isub, however is there a way to make it so whoever has access to the mobile device, can not then change those cache settings? Is it possible to block caching via there Madsonic settings on the server?
Patrick
loungecrasher
Unread postby skopo » 10 Feb 2015, 09:44
From the server side it is not possible. Client hadless the caching completely.
For your luck there is app named Audiophone for iOS.
It has no option for caching at all so it should be great for that purpose :D
skopo
Unread postby loungecrasher » 10 Feb 2015, 14:38
Thanks for that info :)
loungecrasher
Return to Support
