pining music on device while playing music
Unread postPosted: 08 Jan 2014, 03:15
by sjbauer
Hello!
Is it possible to pin music to a device while listening to the music at same time? Currently, I have version 5.4 installed and if I pin say an album to the device and then go and play a different album, it appears that the pining function is canceled the minute the album that I want to listen to starts playing. Should it restart the pinning of the selected album once the album being played is done?
Steve
Re: pining music on device while playing music
Unread postPosted: 28 Jan 2014, 10:17
by mrdrew
+1 here. How does the behavior of the pin function work?
Sent from my SPH-L710 using Tapatalk
