Android Client 5.7
additional Client information
Android Client 5.7
Unread postby Madevil » 21 Aug 2015, 12:19
Android Client 5.7
in Alpha testing
Release Note
General
  • New: add Madsonic 6.0 Support
  • New: add Android Lolipop support
  • Fix: FollowMe: don't clear playQueue
  • Fix: List View don't expand
  • Fix: XML settings import
Has thanked: 1338 times
Re: Android Client 5.7
Unread postby gurutech » 22 Aug 2015, 16:19
Where can I get a copy of this? I purchased the 5.6 from Amazon store, not the Google Play store...
Has thanked: 12 times
Been thanked: 131 times
Unread postby aramisathei » 26 Aug 2015, 13:47
Likewise. 5.6 is available in the google store.
Is there an option to help test this client?
aramisathei
Has thanked: 2 times
Been thanked: 5 times
Unread postby Madevil » 27 Aug 2015, 21:19
gurutech wrote:Where can I get a copy of this? I purchased the 5.6 from Amazon store, not the Google Play store...
I'm sorry, but the beta test phase only works with the Google Play Store.
Unread postby Soleurs » 28 Aug 2015, 03:25
Will this be pushed to the Google beta group soon or will it probably be some time?
Soleurs
Unread postby Madevil » 28 Aug 2015, 03:45
At the moment it's a closed group to find the last issues before it goes to the beta group.
If you want to test, please PM me your google account (email) and i add you to the test group. ;)
Return to Info
