Android Client 5.7
Unread postPosted: 21 Aug 2015, 12:19
by Madevil
Android Client 5.7
in Alpha testing
Release Note
General
  • New: add Madsonic 6.0 Support
  • New: add Android Lolipop support
  • Fix: FollowMe: don't clear playQueue
  • Fix: List View don't expand
  • Fix: XML settings import
Re: Android Client 5.7
Unread postPosted: 22 Aug 2015, 16:19
by gurutech
Where can I get a copy of this? I purchased the 5.6 from Amazon store, not the Google Play store...
Unread postPosted: 26 Aug 2015, 13:47
by aramisathei
Likewise. 5.6 is available in the google store.
Is there an option to help test this client?
Unread postPosted: 27 Aug 2015, 21:19
by Madevil
gurutech wrote:Where can I get a copy of this? I purchased the 5.6 from Amazon store, not the Google Play store...
I'm sorry, but the beta test phase only works with the Google Play Store.
Unread postPosted: 28 Aug 2015, 03:25
by Soleurs
Will this be pushed to the Google beta group soon or will it probably be some time?
Unread postPosted: 28 Aug 2015, 03:45
by Madevil
At the moment it's a closed group to find the last issues before it goes to the beta group.
If you want to test, please PM me your google account (email) and i add you to the test group. ;)
