Re: Android Client 5.1 Release
Posted: 03 May 2013, 21:38
by mlutzow
Marty,
Very nice...the interface just keeps improving. I'm anxiously waiting for the History in the Android app, then it'll be just about perfect!
Posted: 03 May 2013, 23:30
by gurutech
How are you sending the updates to Google Play? Like the last version upgrade (4.0.9 to 5.0), I am showing that the app is "installed", but when I check the application manager to see what version I have, it currently says "5.0", not 5.1 (or whatever the new release happens to be).
I would assume there should be an "update" option, as I have with other apps (although most of the time, they just update themselves automatically).
Any ideas?
Posted: 03 May 2013, 23:47
gurutech wrote:How are you sending the updates to Google Play? Like the last version upgrade (4.0.9 to 5.0), I am showing that the app is "installed", but when I check the application manager to see what version I have, it currently says "5.0", not 5.1 (or whatever the new release happens to be).
Any ideas?
hi,
i found out if you have previously from local installed apk, better you uninstall first and then install new from market
then the upgrade/update will work in the future.
i test the upgrade on some devices myself fine.
Posted: 04 May 2013, 15:32
by mlutzow
Greetings,
I don't know if this a bug or a feature but I've found that if I'm playing an audio file and I would like to 'jump' ahead in the file, if I touch the slider anywhere at some point forward, the slider will jump to the location touched but the audio will stop playing and after a minute or so the app will start playing the next file in the queue. However if I drag the slider (where I can watch the time indicator increment) the audio file will resume playback just fine.
Posted: 04 May 2013, 16:09
by GJ51
mlutzow wrote:Greetings,
I just tested on my server and do NOT see the same behavior. Mine is working properly.
Posted: 04 May 2013, 22:48
by mlutzow
This is using the Android client. The file has completely downloaded to the Android device (Galaxy Note 2) and is in cache. That's when the behavior is exhibited and repeatable.
Regards
Posted: 05 May 2013, 00:18
by nh5
Having a minor issue with the new release. Upon first opening the app, whether I'm connected to my server or using the app in offline mode, upon hitting play now on my selection, the app locks up, I get the madsonic is not responding prompt which I hit ok, app closes then reopens and works normally. Appears to be an issue only since I upgraded from 4.0.8. If I can get any logs or provide anything to help debugging let me know.
Posted: 05 May 2013, 02:37
by mlutzow
I've experienced this issue a few times a well, but it happens when I first launch the app from the widget on my desktop.
