Android Client 5.3
additional Client information
Android Client 5.3
Unread postby Madevil » 22 May 2013, 13:27
Android Client 5.3
Info about coming version
Release Note
[b]Screenshot Gallery http://imgur.com/a/pwfku
Amazon App Store Link
    General
  • New 4x2 Widget
  • Support Gapless playback **new**
  • Support Drag&Drop on Playlist **new**
  • Rework Imageloader better caching**new**
  • some Theme tweaks **new**
  • some bug fixes
    new Themes
  • Light **new**
  • Pink **new**
  • Light Fullscreen **new**
  • Pink Fullscreen **new**
Image Image Image Image Image Image
Has thanked: 1338 times
Re: Android Client 5.3
Unread postby GJ51 » 22 May 2013, 15:21
Does not upgrade from play store. How do you upgrade?
GJ51
Has thanked: 68 times
Been thanked: 106 times
Unread postby Madevil » 22 May 2013, 15:56
GJ51 wrote:Does not upgrade from play store. How do you upgrade?
Sorry ... before I can publish to stores i have to fix a few small errors ;)
i hope i can release it today/tomorrow.
Unread postby GJ51 » 22 May 2013, 19:29
NP - looking forward to it!!
Looks great!
GJ51
Re: Android Client 5.3 (coming soon ...)
Unread postby Magica » 15 Jun 2013, 09:21
Great work on 5.3 Client.
I like the Random Songs feature very much. Is it supposed to work this way? First you choose folder in Select folder section. Then you go and click Random Songs - button, you will see the playlist for songs. When you have choose the folder you expect that playlist will come in this specified folder. But playlist will come randomly in different folder which contains music.
Is it difficult make folder selection in settings where you can choose default folder for random songs? Or same way that is in server side via More-menu, you choose amount of songs and folder where create list.
Thanks.
-m-
Magica
Has thanked: 6 times
Been thanked: 13 times
Unread postby eagle848 » 12 Jul 2013, 17:08
error
rescan not supported server api verizion too old
requires 1.95 but 1.9
running ubuntu 12.04 madsonic 5.0 3510 server software ?
how do you update api ?
eagle848
Has thanked: 4 times
Unread postby Madevil » 14 Jul 2013, 00:29
eagle848 wrote:error
you may have problems with jetty cache, because madsonic 5.0 35xx have REST API 1.10.1
try tp cleanup cache and jetty cache folder.
Unread postby eagle848 » 14 Jul 2013, 20:35
Thanks for reply yeap was cache all sorted
eagle848
Return to Info
