Madsonic Server 6.3 Synology-DSM 6.1.1
Unread postby Madevil » 30 May 2017, 07:06
Madsonic 6.3 on Synology
http://www.synology.com
tested with: DSM 6.1.1.15101-4
  • Perl
  • Java Manager 8
Installation:
  • prepare Synology hardware
  • update to latest Synology DSM 6.1.x
  • create new Volume
  • activate user home service
  • install Perl module
  • install JavaManager module
  • download latest Java JDK 8
  • upgrade Java JDK on DSM
  • reboot Synology
  • install Madsonic 6.3 package
  • start Madsonic service
  • logon as admin user
  • set system output to debug
  • check Madsonic log files
Download:
  • DSM Docker
Installation:
  • install Docker module
  • install Madsonic docker image madsonic/ubuntu-madsonic-beta
Download:
  • Java Manager 7
  • Tomcat 7
Installation:
  • install Tomcat7 module
  • download latest Java JDK 7
  • mkdir /var/madsonic
  • reboot Synology
  • install Madsonic tomcat war
  • start Tomcat service
Download:
Has thanked: 1323 times
Been thanked: 951 times
Re: Madsonic Server 6.3 Synology-DSM 6.1.1
Unread postby Oxize » 10 Jun 2017, 10:18
Not available for normal user. And 6.2 is broken for Synology. So in fact we got nothing now. Not even going to pay if i dont know if it gonna work.
Oxize
Has thanked: 1 time
Unread postby Oxize » 11 Jun 2017, 18:02
Still not working at my side. What you need for debugging/logs?
Oxize
Has thanked: 1 time
Unread postby Oxize » 12 Jun 2017, 18:09
Madevil? What i have to do now? Still getting Failed to install Madsonic. No old stuff are on my nas. Help please.
Oxize
Has thanked: 1 time
Unread postby Madevil » 12 Jun 2017, 22:37
Fixed installer script is in preparation, coming later this week.
Unread postby Oxize » 23 Jun 2017, 16:32
Any updates? Newest DSM is 6.1.2-15132
Oxize
Has thanked: 1 time
Unread postby Aktarus » 28 Jun 2017, 18:39
Hello
I have installed the 6.3 vesion on my DSM 6.1 successfully 1 month ago... after long wait time and many install attempt .. and everithing worked fine ...
But I deceide to install the new version 6.3 today... So I uninstall madsonic and it was ok ... backup is in the public folder ..
But when I want to install the latest 6.3 release, I got the FAIL TO INSTALL MADSONIC error... like before...
I tried tio install with and without the backup restore...without any success ...
I tried to install anither old version like 6.2 .. no success ...
So, for now ... no more Madsonic on my Synoloy (DSM 6.1.2) :( :roll:
What can I do ... please help me ...
MERCI BEAUCOUP ... and sorry for my poor english :?
Aktarus
Unread postby john21wall » 10 Jul 2017, 12:35
john21wall
Return to Synology
