Page 1 of 3
Madsonic Server 5.x Synology-DSM 5.x NAS Plugin
Unread postPosted: 16 Jan 2014, 18:28
by Madevil
Madsonic 5.x Synology-NAS PLugin
http://www.synology.com/
tested with
DSM 5.0-4418, DSM 4.3.3810
This beta package needs this requirements installed:
  • Perl
  • Java Manager
  • Serviio (ffmpeg)
Download
Madsonic5.1-B5060-016.spk
Madsonic5.0-B3860-012.spk
JavaSE: http://pcloadletter.co.uk/2011/08/23/ja ... -synology/
ffmpeg: http://pcloadletter.co.uk/2012/01/25/se ... o-package/
Re: Madsonic Server 5.0 Synology-NAS Plugin
Unread postPosted: 16 Jan 2014, 21:08
by olive069
Very good news!!!!
It will be compatible with all ARM CPU models?
Unread postPosted: 23 Jan 2014, 08:15
by muiz
Awesome
Unread postPosted: 23 Jan 2014, 11:41
by Siutsch
Can't wait ... ;)
Unread postPosted: 03 Feb 2014, 13:24
by olive069
Any progress? Even an alpha version?
Unread postPosted: 28 Feb 2014, 07:54
by Siutsch
Long time no news here ...
Can you perhaps say, from when to expect a release?
I am very excited ... :)
Siutsch.
Unread postPosted: 11 Mar 2014, 11:29
by MuadDib_II
Very good news !!!! :P
I was "forced" to return to Subsonic because there was no Madsonic package available for my NAS, now I'm glad to see that I will be able to use Madsonic once again :D
Can't wait :twisted:
Unread postPosted: 17 Mar 2014, 12:46
by olive069
penumbra wrote:I can`t wait.....
If there is any way to test a beta version - i would be glad !
I'm ready to test and give review too!
Unread postPosted: 28 Mar 2014, 21:54
by olive069
Come on Madevil, bring the magic!
Unread postPosted: 28 Mar 2014, 22:08
by Madevil
olive069 wrote:Come on Madevil, bring the magic!
sorry for the long delay, i'am allready working on the new 5.1 branch,
at the moment i havn't much time to test every hardware type.
meanwhile i can release the old Madsonic 5.0 branch version. :D
Unread postPosted: 29 Mar 2014, 00:06
by olive069
It's rolling!!
No issue until then.
Unread postPosted: 29 Mar 2014, 11:36
by hanshans
What about disk hibernation. Does it stay in hibernation until Its connected ?. If it does, i move it from my server to diskstation 412+
Unread postPosted: 29 Mar 2014, 17:29
by olive069
stertje wrote:where do i finde java and servilo pakages
Add this repo to the package center (options) : http://packages.synocommunity.com
Unread postPosted: 31 Mar 2014, 22:23
by olive069
On my Ds112, i notice some lags especially with large covers and instabillity with transcoding (ffmpeg).
Unread postPosted: 02 Apr 2014, 20:20
by Siutsch
After automatic Perl Update at DSM I get this:
HTTP ERROR: 503
Service Unavailable
Powered by Jetty://
I reinstalled, but same problem.
Unread postPosted: 07 Apr 2014, 11:57
by olive069
After a few days using Madsonic 5.0 on my Syno DS112 runing on DSM 5.0.
- better use last java SE ver 8 : better disk & RAM usage.
- transcoding works well
- i found that tag reading is worse than subsonic : some of my albums have no tags at all.
- nice interface, smooth and slick!!
Thanks Mad for releasing it and i'm looking for 5.1 update!
Unread postPosted: 07 Apr 2014, 14:08
by olive069
lionelkw wrote:Do you have some special setup for making transcoding work? Apart from installing Serviio.
No just copy the ffmpeg binary from serviio folder, chmod 655 and usual command line in Madsonic transcoding options. I only use Madsonic for audio files.
Unread postPosted: 10 Apr 2014, 08:31
by HolgerWill
Can somebody please describe how to copy ffmpeg from serviio folder.
Step by step ??
Unread postPosted: 10 Apr 2014, 08:55
by HolgerWill
Now i have the following file in the following folders.
But transcoding still doesn`t work:
-rwxrwxrwx 1 root root 153616 Apr 10 07:47 ffmpeg
/usr/syno/synoman/webman/3rdparty/Madsonic/transcode
/volume1/@appstore/Madsonic/transcode
my downsample command is:
ffmpeg -i %s -ab %bk -v 0 -f mp3 -
Unread postPosted: 10 Apr 2014, 09:54
by olive069
Cn you post your madsonic log when you attempt to transcode a file?
