HTTPS connection with the Synology server ?
Unread postPosted: 29 Mar 2014, 10:32
by MuadDib_II
Is there anyway to enable a HTTPS connection with the Synology Server?
I've tried to connect with my phone's browser and it goes directly to the http 4040 port, I think it's the same with the mobile app.
With the PC server I always used the HTTPS connections in the port 4041...
Thanks in advance,
Marc
Re: HTTPS connection with the Synology server ?
Unread postPosted: 02 Sep 2014, 14:22
by MuadDib_II
Sorry for the up, but no one knows how to do it ?
I'm using the 5.1 Public Preview Server with my Synology NAS.
Thanks in dvance
Unread postPosted: 04 Sep 2015, 23:07
by onechance13
You need to edit the ports within the deamon e.g. madsonic.sh to look for HTTPS and ports 4141 for example.
Sent from my A0001 using Tapatalk
