Media folder index style explanation?
Unread postby abrenoch » 10 Jun 2014, 00:11
Hi.. I am trying to figure out just what the heck these different "index styles" are for media folders, but I cannot for the life of me find a description of what the different types are, let alone what they do..
Could somebody enlighten me please?
I was hoping that this option would enable me to exclude certain media sources from the 'random' list.. Would this help me achieve that, or should I look for a different solution to that?
abrenoch
Re: Media folder index style explanation?
Unread postby GJ51 » 10 Jun 2014, 14:37
The short version...
It just changes the way files are displayed in the left column.
i.e. numbers first or last, XYZ displayed together or as X, Y, Z separately and so on.
The Settings/General panel controls and explains it.
I'm not sure about the random list as I don't keep up with all the changes. I have suggested that the left column dictate what appears in the main panel so that you only see in "Random" items that are in the left column. I think that's integrated, but I don't know where/how it's controlled. I go through Settings occasionally and try to figure out what everything does.
HTH
GJ51
Has thanked: 68 times
Been thanked: 106 times
Return to Info
