Theme add or better remove theme template
ForSSux
Has thanked: 10 times
Been thanked: 12 times
Unread post by ForSSux »
Hi There,
I have tried to alter a theme to suit my needs ...with mixed results.
In linux I have expanded the subsonic.war file... with
jar -xvf subsonic.war
In this directory structure I altered some icons and I also changed the .properties file here
In the "WEB-INF\classes\net\sourceforge\subsonic\theme" I also added a couple lines in "themes.txt" to allow my theme to be listed in Subsonic.
This comes from http://forum.subsonic.org/forum/viewtop ... eme#p55048
Here is 7-zip to extract used but how to pack it in?
I then did a
jar -cvf subsonic.war index.html WEB-INF
I then moved this file over the old one in /var/subsonic/standalone
Is this the right procedure?
How am I to do this In Windows 8 or 7 ?
Can somebody help me?
Kind Regards
Guy Forssman
ForSSux
Re: Theme add or better remove theme template
If you Just want to remove a theme...
then edit the following file
C:\madsonic\jetty\3860\webapp\WEB-INF\classes\net\sourceforge\subsonic\theme\theme.txt
remove from this list the themes you don't want and then simply restart Madsonic in the Madsonic Control Panel
The choice is now limitted
Guy Forssman
These users thanked the author ForSSux for the post (total 2):
GJ51Madsonic
Rating: 15.38%
GJ51
Has thanked: 42 times
Been thanked: 83 times
Unread post by GJ51 »
C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\madsonic\WEB-INF\classes\org\madsonic\theme
Here's the location in the Tomcat war version on Windows.
Thanks Guy
