[FAQ] Madsonic + nginx proxy
Unread postby Madevil » 03 Jun 2017, 14:01
setup a new test environment as follow:
*) install System (debian9)
*) install Oracle Java (JDK8)
*) install Madsonic Server (6.3.9500)
*) install nginx (1.10.3)
*) create selfsign cert /etc/nginx/cert.crt
cd /etc/nginx
sudo openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout /etc/nginx/cert.key -out /etc/nginx/cert.crt
*) edit nginx config
sudo nano /etc/nginx/sites-enabled/default
*) replace nginx config
server {
    listen 80;
    listen [::]:80;
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    ssl_certificate           /etc/nginx/cert.crt;
    ssl_certificate_key       /etc/nginx/cert.key;
    ssl on;
    ssl_session_cache  builtin:1000  shared:SSL:10m;
    ssl_protocols  TLSv1 TLSv1.1 TLSv1.2;
    ssl_prefer_server_ciphers on;
    access_log  /var/log/nginx/madsonic.access.log;
    error_log   /var/log/nginx/madsonic.error.log;
    location /music {
      proxy_set_header Host              $host;
      proxy_set_header X-Real-IP         $remote_addr;
      proxy_set_header X-Forwarded-For   $proxy_add_x_forwarded_for;
      proxy_pass                        http://localhost:4040;
      proxy_redirect                    http:// https://;
      proxy_read_timeout                90;
      add_header X-Frame-Options        SAMEORIGIN;
*) edit Madsonic settings:
sudo nano /etc/default/madsonic
MADSONIC_ARGS="--context-path=/music --port=4040 --init-memory=256 --max-memory=512"
*) restart services
sudo service madsonic restart
sudo service nginx restart
That's it! :)
Has thanked: 1326 times
Been thanked: 963 times
Return to Info
