Moods & Genre Not Available
Unread postby magikbus » 21 Feb 2013, 14:10
I have installed Madsonic V 4.8.3320.beta3 and I am unable to select the Genre and Moods Icon options in the settings section. Is there something else I need to turn on of install to get that functionality working?
magikbus
Re: Moods & Genre Not Available
Unread postby Madevil » 23 Feb 2013, 19:54
Hi, in this version the option are only placeholders.
To enable moods you must upgrade to the newest Build,
But genre ist at the moment not implemented.
Has thanked: 1339 times
Unread postby magikbus » 02 Mar 2013, 04:19
Okay I upgraded to version 4.8.3340.beta3 and I now see the Moods icon, but when clicked it only says please scan your library before. I have run the scan already, but it still says that. Does it take a day or so to compile?
magikbus
Unread postby gurutech » 02 Mar 2013, 05:31
Newest build is 3350, but the same thing happens with that build as well. It appears that Moods will be something added in a later build.
Has thanked: 12 times
Been thanked: 131 times
Return to Info
