[FAQ] Advanced User Statistics
Unread postby Madevil » 13 Mar 2013, 02:08
if you have simple SQL knowledge you can go to db.view and use this query
SELECT * from statistic_user, media_file where statistic_user.media_file_id = media_file.id and username = 'admin'
this query should show you all information's about played entries incl. the username.
SELECT * from statistic_user, media_file where statistic_user.media_file_id = media_file.id and username = 'guest' and played < '2013-03-13 01:25'
or drill down the Results.
Has thanked: 1339 times
Return to Info
