[FAQ] Moods
[FAQ] Moods
Unread postby Madevil » 07 Mar 2014, 10:40
Moods Support
You can use Moods only if your Mediafile-Tags support this.
Moods are only supported if you use ID3v2.4 Tags, if you have only ID3v2.3 it doesn't work! \c:=
Madsonic support ID3v2.4 but many compatibility problems still exists with other SW/HW player,
test it with a banch of files, if all your hardware support ID3v2.4.
To convert/fill & correct your Tags i used the following Tools
[*]MP3-Tag - http://www.mp3tag.de/en/index.html
[*]MusicBrainz Picard - http://musicbrainz.org/doc/MusicBrainz_Picard
[*]LastFMPlus - Extended Picard Tagging - http://wiki.musicbrainz.org/Picard_Docu ... Lastfmplus
Finally it looks like
Has thanked: 1326 times
Been thanked: 963 times
Re: [FAQ] Moods
Unread postby addseo1115 » 10 Aug 2015, 03:59
Tags support this.
Re: [FAQ] Moods
Unread postby frank2228 » 16 Aug 2016, 00:18
Here is another plugin for MusicBrainz Picard which should accomplish the mood tagging.
I found this after realizing the lastfmplus plugin was not working for me. I read somewhere that it stopped working after a change in the last.fm site but cannot seem to find it now. Can anyone confirm?
Has thanked: 32 times
Been thanked: 10 times
Return to Info
