[FAQ] Moods
Posted: 07 Mar 2014, 10:40
Moods Support
You can use Moods only if your Mediafile-Tags support this.
INFO
http://id3.org/id3v2.4.0-changes
http://www.jthink.net/jaudiotagger/tagmapping.html
Moods are only supported if you use ID3v2.4 Tags, if you have only ID3v2.3 it doesn't work! \c:=
Madsonic support ID3v2.4 but many compatibility problems still exists with other SW/HW player,
test it with a banch of files, if all your hardware support ID3v2.4.
To convert/fill & correct your Tags i used the following Tools
[*]MP3-Tag - http://www.mp3tag.de/en/index.html
[*]MusicBrainz Picard - http://musicbrainz.org/doc/MusicBrainz_Picard
[*]LastFMPlus - Extended Picard Tagging - http://wiki.musicbrainz.org/Picard_Docu ... Lastfmplus
Finally it looks like
