gurutech wrote:Will there be a conversion tool for upgrading from 5.x to 6.0 or 6.1?
Or is there a way to do this manually? Basically only looking for migrating the userbase over - everything else I can do manually with minimal impact.
To only save you're user list-settings hear is a trick :
get the madsonic.script files in the DB folder ,
in this files you can find all the users config and password and things !
save all those lines delete the rest ( be careful and see which line is for what ! )
If DB are the same structure only go paste the lines into the db.view of youre madsonic server ( go to url
http://exemple.net/db.view )
and press enter, now you're settings are migrated to you're DB
IF the line structure of the new db don't fit to the older, you need to do it manually ( use a text editor and build you're ownline following the new structure ! )
Insann
