Please Help
glun298
Please Help
Unread post by glun298 »
So i have 2 folders where my media is stored one called TV one called Films but these folders are password protected using .htaccess as its on a server and i dont want praying eyes to be able to get on from the web, but the problem is i have know idea how to grant access to madsonic can anyone please help
glun298
Re: Please Help
I have worked out how to fix this problem and incase it helps anyone else i have pasted what you .htaccess file should look like
AuthName "Secure Area"
AuthType Basic
AuthUserFile /to/where/your/passwords/are/stored/.htpasswd
require local
require valid-user
so the fix was to add
require local
its also important that its before
require valid-user
if you put it after it still wont work
Hope this helps someone :D
These users thanked the author glun298 for the post:
