Chromecast = NoGo
Posted: 15 Nov 2016, 19:07
I'm using chrome browser Version 54.0.2840.99 m (64-bit) on a Windows 10 version 1607 (Build 14393.447) running Madsonic 6.1.8740 Premium in Docker.
I have a Chrome AudioCast that works just perfect with all my other apps (windows + Android + iPhone), but Madsonic does not work.
When I click on the Chromecast icon on the Madsonic Taskbar, the Chrome dialog opens and I can select the AudiaCast. I hear the familiar 'blip' in my speakers, but the Play button in Madsonic doesn't react on mous clicks. It isn't like it appears to be playing, just missing the sound - no, it doesn't even change into the pause icon. It doesn't make any difference if I right click on an album and press play. Still nothing happens. I I have a track playing locally, and then switch to cast while playing, playback immediately stops - and that's it. When I switch casting off again, playback resumes locally.
I suspect that Madsonic running inside a container isn't able to parse the URL correctly to the Chromecast.
Is there anyway I can debug this - or investigate a log to see what's going on?
