[Solved] whats is a genre map ? and how to use it ?
Unread postby Matt Zornig » 04 Mar 2017, 22:53
after only getting a useless result, searching for genre+map I'm quite sure, I can ask this maybe simple question:
What for is " Organize by genre map" and how could it be useful ? and...which config file is meant?
via Settings->media folders
Been thanked: 19 times
Re: whats is a genre map ? and how to use it ?
Unread postby Matt Zornig » 03 May 2018, 05:24
Trying to answer my own question,
I guess, a genre map might be here to find (after activating the above setting and a full rescan of your music folders):
Choose "Genre Radio" from the left navigation:
Navigation
See the map:
A Genre Map
Click on a genre and some albums should pop up.
Return to Support 6.x
Users browsing this forum: No registered users and 5 guests
