HTTP ERROR: 503 Service Unavailable / Failed to initialize d
Unread postby Matt Zornig » 21 Mar 2017, 21:45
BROWSER: FF 52.x
today, out of the blue, I only see this, after trying to open the webguy
HTTP ERROR: 503
Problem accessing /. Reason:
    Service Unavailable
stoping/starting the madsonic package log:
[2017-03-21 21:35:17,008] WARN HsqlDaoHelper - Checking database schema ...
[2017-03-21 21:35:19,791] INFO HSqlSchema02 - Database table 'music_folder_tasks' not found.  Creating it.
[2017-03-21 21:35:19,802] ERROR HsqlDaoHelper - Failed to initialize database.
org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [create cached table music_folder_tasks (id identity,music_folder_id int not null,found int default 0 not null,scan datetime not null,status varchar,result varchar,comment varchar,enabled boolean default true not null,foreign key (music_folder_id) references music_folder(id) on delete cascade)]; nested exception is java.sql.SQLSyntaxErrorException: object name already exists: MUSIC_FOLDER_TASKS in statement [create cached table music_folder_tasks (id identity,music_folder_id int not null,found int default 0 not null,scan datetime not null,status varchar,result varchar,comment varchar,enabled boolean default true not null,foreign key (music_folder_id) references music_folder(id) on delete cascade)]
   at org.springframework.jdbc.support.SQLExceptionSubclassTranslator.doTranslate(SQLExceptionSubclassTranslator.java:92)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:407)
   at org.madsonic.dao.schema.hsql.HSqlSchema02.execute(HSqlSchema02.java:90)
   at org.madsonic.dao.HsqlDaoHelper.checkDatabase(HsqlDaoHelper.java:129)
   at org.madsonic.dao.HsqlDaoHelper.<init>(HsqlDaoHelper.java:58)
   at org.madsonic.dao.DaoHelperFactory.create(DaoHelperFactory.java:39)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
   at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:938)
   at org.madsonic.booter.deployer.MadsonicDeployer.deployWebApp(MadsonicDeployer.java:243)
   at org.madsonic.booter.deployer.MadsonicDeployer.<init>(MadsonicDeployer.java:100)
Caused by: java.sql.SQLSyntaxErrorException: object name already exists: MUSIC_FOLDER_TASKS in statement [create cached table music_folder_tasks (id identity,music_folder_id int not null,found int default 0 not null,scan datetime not null,status varchar,result varchar,comment varchar,enabled boolean default true not null,foreign key (music_folder_id) references music_folder(id) on delete cascade)]
   at org.hsqldb.jdbc.JDBCStatement.fetchResult(Unknown Source)
   at org.hsqldb.jdbc.JDBCStatement.execute(Unknown Source)
   at org.springframework.jdbc.core.JdbcTemplate$1ExecuteStatementCallback.doInStatement(JdbcTemplate.java:421)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:396)
   ... 69 more
Caused by: org.hsqldb.HsqlException: object name already exists: MUSIC_FOLDER_TASKS
   at org.hsqldb.SchemaObjectSet.checkAdd(Unknown Source)
   at org.hsqldb.SchemaManager.checkSchemaObjectNotExists(Unknown Source)
   at org.hsqldb.StatementSchema.setOrCheckObjectName(Unknown Source)
   at org.hsqldb.StatementSchema.getResult(Unknown Source)
   at org.hsqldb.StatementSchema.execute(Unknown Source)
   at org.hsqldb.Session.executeDirectStatement(Unknown Source)
   ... 73 more
[2017-03-21 21:35:19,819] INFO HsqlDaoHelper - Checking HSQLDB version: 2.3.4
[2017-03-21 21:35:20,978] INFO SettingsService - Java: 1.8.0_121, OS: Linux
[2017-03-21 21:35:20,999] INFO SettingsService - write transcode path to property file: /bin
[2017-03-21 21:35:21,203] INFO SettingsService - ffmpeg: ffmpeg version 2.7.1 (22.02.2017) Copyright (c) 2000-2015 the FFmpeg developers
[2017-03-21 21:35:21,203] INFO SettingsService - Madsonic scanMode: MIXED
[2017-03-21 21:35:21,205] DEBUG VersionService - Resolved local Madsonic version to: 6.2.9080.619dd31
[2017-03-21 21:35:21,254] DEBUG UserService - Checking User accounts ...
[2017-03-21 21:35:21,461] DEBUG SecurityService - Updated user default
[2017-03-21 21:35:21,461] DEBUG UserService - Checking Default User. Done
[2017-03-21 21:35:21,488] DEBUG SecurityService - Updated user guest
[2017-03-21 21:35:21,489] DEBUG UserService - Checking Guest User. Done
[2017-03-21 21:35:21,534] DEBUG SecurityService - Updated user node
[2017-03-21 21:35:21,535] DEBUG UserService - Checking Node User. Done
[2017-03-21 21:35:21,734] DEBUG MediaScannerService - WATCHDOG:RUN: doUpdateTasks()
what could it be?
Been thanked: 20 times
Re: HTTP ERROR: 503 Service Unavailable / Failed to initiali
Unread postby VatsanM » 04 Apr 2017, 01:01
Any luck in fixing the issue? I have the same problem.
VatsanM
Unread postby deusxanime » 25 May 2017, 22:38
I think I figured this out, if it is the same thing I had. Did you change the user name that madsonic runs under in the /etc/sysconfig/madsonic file and restart service before logging in for the first time? I think it can't create/initialize the db if you do that. Set it back to run as root, access the site for the first time and log in as admin, reset password, maybe do a couple things so that the db is created. Then go back and change the madsonic config file and change the user and restart the service.
deusxanime
Return to Support 6.x
