Sonos on Synology-- Can´t connect
Posted: 25 May 2017, 12:15
by jflocke
i am running my synology DS415+ on DSM 6.0.2-8451 Update 9.
Madsonic is running on MADSONIC 6.2.9080.619dd31.20161222.0327 .
Sonos is on 7.2 - 35339010.
When i try to add Madsonic as a service in Sonos, i always get the problem that i can´t connect to sonos.
25.05.17 12:59] INFO SonosService Found Sonos controllers: [192.168.0.76, 192.168.0.79, 192.168.0.17, 192.168.0.25, 192.168.0.29, 192.168.0.18, 192.168.0.30, 192.168.0.27, 192.168.0.14, 192.168.0.23]
[25.05.17 12:59] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.76, SID 244, and Madsonic URL http://172.17.0.1:4040/ws/Sonos
[25.05.17 12:59] INFO SonosServiceRegistration Sonos controller returned: success!
I guess that there is a problem with the madsonic url.. i don´t know where to change it.. can any1 help me out here? do you need any more information?
thank you so much.
julian
Re: Sonos on Synology-- Can´t connect
Posted: 30 May 2017, 14:50
try to bring the Madsonic server to the same ip subnet (192.168.0.x) Sonos products can't broadcast to different subnets.
to config your Madsonic url rewriter go to Settings > Network
Posted: 30 May 2017, 19:25
by jflocke
thanks for your help. I tried to change it but get the following error:
Status: Could not connect to http://192.168.0.38:4040. (HttpHostConnectException)
can you help me out here?
thank you so much
